12V input to 3 fixed voltage levels output, controlled by a pushbutton.
Discussion in 'Power Electronics' started by LCM, Jun 2, 2021.
  1. LCM
    LCM
    Jun 2, 2021
    Hi
    Would anyone be able to point me in the right direction (design examples, components to use) in order to make a controller that via a push button cycles through 4 fixed output levels (off, 33%, 66%, 100%). See attached drawing for wanted functionality details.
    Br,
    LC
  2. Harald Kapp
    11,415
    2,619
    Use a microcontroller (e.g. Arduino, PIC, ...) to control the sequence of voltage steps.
    Use the microcontroller to set a programmable voltage regulator to the desired output voltage. Some examples for programmable voltage regulators:
    You surely will find many others.
