How to measure the power of antenna (RF)
thanhvu94
Oct 1, 2016
3
Oct 1, 2016
3
Hello,
I'm doing a project about aquatic drone and we have 2 antennas on it. We want to measure the power of the two antennas and compare with each other to find out whose signal is stronger. Can you give me some ideas about this? (circuit, website, books...)
Thank you so much
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
How do you think we can answer that with so little info. Give us all the details of your project.
Adam
davenn
14,264
14,264
antennas don't have/produce power
As Adam responded tell us much more
but a field strength meter is usually used to determine radiated signal strength
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Or if it's the received signal strength you want to measure, provide a fixed gain to both, and compare the amplitude of the signals.
Assuming the antennas have the same impedance, the amplitude week be proportional (not directly) to power. For received signed it's normally about the amplitude (possibly in uV) than the received power (possibly in uW) anyway.
thanhvu94
Oct 1, 2016
3
Oct 1, 2016
3
@adam, davenn: Sorry for my confusing question. Just like davenn mean, my professor says that the idea of our project is just to measure and compare the signal strength from 2 antennas to choose which one receive better signal (We will control the aquatic drone from a riverbank). But my team is new to RF so we don't have much idea to discuss.
Thank you.
thanhvu94
Oct 1, 2016
3
Oct 1, 2016
3
Thank you for your reply, can you be tell me which tool/circuit/module we can possibly use to measure that?
(*steve*)
25,510
25,510
Is this to compare antennas and then decide which one to use, or will the device have multiple antennas that it will dynamically chose from?
If the former, you could simply try them one by one and see which one allows reliable control at the longest range.
