High-voltage low-amperage computer -- any advantages?
R
Radium
Hi:
Would a computer designed to use high-voltage, low-amperage have any
advantage over conventional computers? In this high-volt, low-amp PC,
all of the components [motherboard, cpu, memory, video system
(including the monitor), sound system (including the speakers)] rely on
the high-voltage, low-amperage electricity. Speakers and monitor are
purely digital and also use the high-voltage, low-amperage digital
electricity. Speakers do not contain any diaphragm, instead they rely
on "electrifying" the air -- similar to the Ionovac speaker -- to
produce sound. The electric current directly causes the air molecules
to vibrate and produce sound -- this makes it easy to reproduce
high-frequency sounds than using a conventional speaker.
In this system, the voltage is high but the amperage is low.
The wattage of this system, however is around the same as that of the
average PC.
In addition, the only insulator is air. Other than that its all
metallic conductors.
Though this PC uses wattages around the same as most other PCs, the
voltages required are enough to generate the bluish-white lights
similar to those emitted from stun-guns [another example of extremely
high-voltage, low-amperage equipment].
This is a "plasma" computer.
Radium
M
Michael A. Terrell
Radium said:
Hi:
average PC.
Radium
No, this is another of your pathetic attempts to troll the
sci.electronics newsgroups.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
R
Radium
Michael said:
Radium said:
Hi:
average PC.
Radium
No. I am asking a serious questions and would appreciate serious
answers.
A
Alan B
Radium said:
Hi:
average PC.
Radium
answers.
Allrighty then. I'll take you at your word. All you have to do is
completely re-design the entire semiconductor and audio-visual industries.
It's a bit of a bite to chew, but have at it! Fill us in when you're done.
Although I'm afraid the concept exceeds the "basics" part of the newsgroup
charter (just a bit), I think it's a splendid project.
M
Michael A. Terrell
answers.
Your questions look like you are throwing darts at a bunch of words
and posting the hits as questions. If you really are serious you need
to pick up some basic books on electronics and learn how to ask valid
questions.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
The problem is that insulation for highvoltage in densly packed chips is not
a working solution. Add to that slowspeeds due excessive rise times.
(reach 1000V in a few ns in a chip.. don't think so..)
The only benefit highvoltage gives in this context is in the powersupply that
could use very long cables. However.. I dault it's useful anyway.
Dead on arrival IOW.
If you look at current trends it's towards lower volts (like 1.2V). Makeing
your powersupply an excellent welder. Which some unfortunate people have
experienced due catastrophic failure (hello AMD ;)
M
Michael A. Terrell
redbelly said:
Nobody believes this, no matter how many times you say it.
He doesn't even believe it.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
