"Vale" wrote in message
Thanks all.I solved, hope for long time.
I've been luky, the dirt that was on the meter case display window was
perfectly corresponding to the dirt line on the display.
So I found the right position.
It has been not so easy to align the display on pcb, I supplied the meter
with a voltage, tried hundreds of positions until it displaied the rights
measurement.
I got help from a pair of chinese spring loaded clamps to firmly block the
display and put some drops of cyanoacrylate on corners.
Than used plenty of epoxy glue to make it stable.
The meter now works quite perfectly, only the last digit is incomplete, but
I'm happy anyway.
At least that experience has provided more knowledge to zebra gadgets.
Thanks everybody and....don't keep your meters too clean!
What brand is your meter? You can probably order parts for it if it is not
too old. When you do order parts, order new zebra strips aswell.
Shaun
