M
Michael
Hi - I'm working on attaching a laptop CD-ROM to an Internet appliance (a
Virgin Webplayer). Anyways - to do this I have to make an adapter that
converts between the 50 pin CD-ROM connector to the 44 pin notebook hard
drive style connector. I'm making a dual sided circuit board to do this -
with one plug on each side of the board - directly across from each other.
Can you see this causing any interference problems? Also - most of the
traces will be the exact same length by design (including DD0-DD15, and
most everything else except for DMARQ, /DIOR, Spindle sync: cable select,
and IORDY) So hopefully you can picture what I'm saying - you can probably
see that this will be a very small little board (which is very important -
I don't have much space to work with) So - will this work? Thanks so much
for your help!!
Mike
for your help!!
Mike
