In (John Larkin):
IIRC, the tube just needs the specified DC voltages and currents present at
each leg of the tube, right? Maybe I'm way out of my league here, but what
do we think about DC --> 10KHz chopper --> step-up transformer -->
multi-tapped toroidal step-up transformer --> leg to each division voltage?
Just tap off the toroid at the appropriate number of secondary turns, add a
HV diode and smoothing cap for each and be done with it. Not as simple as a
resistor string, but might dissipate less power? Of course this assumes a
common ground, and might swing all over the place when first fired up...
sorry just throwing out ideas.
Good to have some new blood in the discussion Mark! Thanks for the
comment.
It has promise, but I think there are problems....
Ultra miniature transformers have standby power problems. When the
actual power needed by the tube is so small, any standby power wasted
in a linear transformer amounts to a major loss. I did have a
discussion with Pico Transformers Inc. several years back, and there
is no way around this. If you apply ac to the input of a transformer
with a very light load on the secondary, the transformer primary
itself is gonna draw alot of current due to lack of impedance in the
primary. You can add more turns to make a higher impedance, but then
you loose it all when you look at the losses in the secondary due to
reflected reactance of the secondary (which is the SQUARE of the step
up ratio). This looks like a shunt inductance and gets to be a major
problem with large primary inductance.
There is another problem too.... The 1st stage draws about 100 ua, the
top dynode draws fA. A transformer is going to have problems supplying
even steps of output voltage because there is a one million times
ratio between the current the different windings supply. Your nice 100
volt steps might be 100v, 103v, 106v, 110v, 120v, 140v, 170v, 200v
etc.
If you really put 200 volt differential voltage on the upper dynodes,
the tube arcs- between the upper dynodes.
Can you see anyway around these problems??
A
