38 khz IR diode driver
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
The maximum current for the 2N2222 is 800mA which would require a clip on heat sink or large copper area on the PCB connected to the emitter. The maximum current for the LED is 1050 mA which is too much for the transistor. Now this does depend on whether your pulsing the LED or if it's on continuous and whether you want it at full power. It is likely you will need to change all three components or as a minimum depending on your answers to my questions just the two resistors.
Adam
