W
Walter Contrata
Greetings,
Please explain the physical mechanism for thyristor function. Why
does current continue to flow from anode to cathode after current to
the gate has been turned off?
I have found a diagram of the thyristor structure at
http://www.allaboutcircuits.com/vol_3/chpt_2/9.html
It shows an p+/n-/p/n+ stack, with the following ohmic contacts
top p+ layer = anode;
p layer = the gate;
bottom n+ layer = the cathode.
The bottom three layers, n-/p/n+, look like the collector, base, and
emitter of an NPN bipolar transistor, but instead of an n+ collector
ohmic, the thyristor has p+.
According to several sources, the thyristor is normally biased with
the anode positive and cathode negative, like an NPN bipolar
transistor. Like the transistor, negligible current flows from anode
to cathode until a positve current flows into the gate. However,
unlike the NPN, this current does not stop after the gate current
returns to 0. Why?
My apologies for multiple postings.
Best Regards,
p layer = the gate;
returns to 0. Why?
Best Regards,
