Guys, anyone??
Anyway I have done some homework [not nearly enough] and concluded to the following:
Let me recap first:
a) I want to pulse an Easy Driver V4.4 which will drive a 200 step/rev [1600 step/rev microstepping] stepper motor.
b) I want to create the pulse with the use of a crystal oscillator and frequency division.
Please feel free to correct me! This is by far the most difficult attempt so far in electronics for me.
1) I could use a 1.8432 MHz crystal [ I found this one on ebay:
http://www.vanlong.com/download/HC49U.pdf ]
2) Make a "Pierce Oscillator" circuit [ Something like this:
3) Divide the 1.8432MHz frequency by 1152 (1.843.200/ 1152 = 1600) with the use of a divide-by-n counter [ Something like this:
http://www.ti.com/lit/ds/symlink/cd4059a.pdf ]
Questions:
0) Does all of the above make any sense? [My experience in electronics counts less than 2 months and maybe I miss very important stuff needed to implement all this]
1) Is this all possible to do
without an oscilloscope?? [critical]
2) The crystal does not mention (I think) the Voltage of operation in the datasheet. So at what voltage should I operate it? Are there limits?
3) I can't [with my current knowledge] decide as for which IC should be used to make the frequency division.
By taking a look to this link [
http://www.digikey.com/product-search/en?Cat=2556429&k=divider] from the "Long duration timers - Notes for beginners" post by *steve* in this forum, I lost it completely..
Directions for the blind please..
I did some experimenting with a 555 timer circuit and a 14 stage ripple binary counter and all went well except for the fact that even though the IC is a BINARY counter the leds
blinked FOUR times for it to go to the next stage??? Unexplicable to me..
Then I did a bit more experimenting with a ceramic resonator (400.000KHz) and the same 14 stage ripple counter and it NEVER worked. Not even 1 led ever blinked... Will try again.
Oh, I forgot.. The purpose for all this is to be able to run the crystal - divider circuit on common e.g. 1.5V pack or 9V batteries
and the Easy Driver on a Sealed Lead Acid battery so that the whole above project becomes as accurate as possible and at the same time as portable as possible..
Ideas, suggestions...
eheadj
