Video Plug help please!!
Jesse
Hello all,
I have a problem. I have a simple video switcher I purchased. I am using
it with a projector. What I need to do is generate a black video signal I
can connect to one of the switches 4 inputs so it outputs black video to the
projector. I have been told that soldering a 75ohm resistor to a composite
plug(center to ground) and plug it into an input will generate a black
signal. Is this correct? If not, what is the easiest way of accomplishing
this?
Thank you in advance,
Jesse
K
Ken Taylor
Jesse said:
Hello all,
this?
Jesse
Assuming that the connector is a BNC (seems most likely) then just go and
buy a 75 Ohm BNC termination from a parts supplier or radio or video store.
Frys Electronics have one which is F-type connector if that's what you have:
http://shop4.outpost.com/product/1525076
otherwise Arrow (www.arrow.com), just for one, have them.
Ken
Jesse
Thanks Ken
And just to make sure, that will generate a black signal on the screen so
the projector wont say "No Source Detected"
Once again,
John Jardine
Jesse said:
Hello all,
this?
Jesse
Sorry but this isn't much help but shows it's not difficult ...
My monitor prints "NO SYNC" with no video input. I generated a pretend sync
using a CD4093 quad schmitt. Basically just a gated couple of oscillators
and summing resistors, no great precision. The monitor just thinks it's
seeing a Black picture.
(I no longer have the unit or it's circuit. )
regards
john
R
Rich Grise
Thanks Ken
No, it won't. It will generate a "No Source Detected". A black signal is not
the same as no signal at all, you see - it would have to have all the sync
pulses, just like a TV picture where you've left the lens cap on the camera.
i.e., to really do it right, you need more than just a terminator. There
used to be sync generator chips, but I don't know if anybody even still
makes them.
Good Luck!
REF ---v
Jim Thompson
makes them.
Good Luck!
[snip]
Fairchild 74ACT715 ??
...Jim Thompson
Jesse
makes them.
Good Luck!
[snip]
...Jim Thompson
I found the semi-conductor online and it is exactly what i need. Thank you
very much everyone!!!!!
Jesse
