Jesse
Hello all,
I have a problem. I have a simple video switcher I purchased. I am using
it with a projector. What I need to do is generate a black video signal I
can connect to one of the switches 4 inputs so it outputs black video to the
projector. I have been told that soldering a 75ohm resistor to a composite
plug(center to ground) and plug it into an input will generate a black
signal. Is this correct? If not, what is the easiest way of accomplishing
this?
Thank you in advance,
Jesse
this?
Jesse
