colin said:
maybe you dont need to go ac-dc-ac,
maybe you could just put a bidirectional switcher,
ie 2 mosfets back to back or inside a bridge rectifier
and feed them with a fixed duty cycle.
this would give you a fairly close fraction of the AC input.
I havnt given this much thought yet,
coffee not working at all today,
you would also need a second bidirectional switch driven in antiphase to
clamp the voltage,
after the first fet before putting it into an LC filter.
this would be like a flywheel diode wich ofc you cant use a diode becuase
its AC,
so its like a synchronous diode.
usual bootstrapped mosfet drivers might be a challenge,
or you go with opto coupled with seperate power supplies.
Colin =^.^=
I have done some experimenting and simulation for this type of application.
I used two IGBTs or MOSFETs in series, with the emitters or sources
connected together to a common rail. The same PWM signal can drive both at
the same time, but it might be better to alternate the drives at the zero
crossings. I found that a parallel LC circuit at multiples of the PWM
frequency helped reduce the chopped waveform to be fairly smooth.
It is also necessary to provide a current path during the off period of the
PWM. This complicates matters, but I have simulated it by using an
optoisolator, a bridge rectifier, and a MOSFET. The LTSpice ASC file is at
the end of this post. I was simulating a high current AC source, so I have
a transformer with a high ratio and a low impedance output.
There's probably a better way, but this proves the concept.
Good luck,
Paul
Version 4
SHEET 1 1072 692
WIRE -432 -80 -512 -80
WIRE 32 -80 -224 -80
WIRE 272 -80 112 -80
WIRE 304 -80 272 -80
WIRE 304 -64 304 -80
WIRE -304 0 -432 0
WIRE -224 16 -224 -80
WIRE 304 16 -144 16
WIRE 304 48 304 16
WIRE -560 96 -592 96
WIRE -528 96 -560 96
WIRE -512 96 -512 -80
WIRE -512 96 -528 96
WIRE -480 96 -512 96
WIRE -352 96 -400 96
WIRE -304 96 -304 0
WIRE -304 96 -352 96
WIRE -272 96 -304 96
WIRE -224 96 -272 96
WIRE -96 96 -144 96
WIRE 224 96 -96 96
WIRE -592 192 -592 96
WIRE -528 192 -528 96
WIRE -480 192 -528 192
WIRE -352 192 -352 96
WIRE -352 192 -416 192
WIRE -272 192 -272 96
WIRE -224 192 -272 192
WIRE -208 192 -224 192
WIRE -96 192 -96 96
WIRE -96 192 -144 192
WIRE 224 208 224 96
WIRE -224 240 -224 192
WIRE -96 240 -96 192
WIRE -272 256 -272 192
WIRE -144 256 -144 192
WIRE 320 288 272 288
WIRE 352 288 320 288
WIRE 416 288 352 288
WIRE 512 288 416 288
WIRE 512 304 512 288
WIRE -144 320 -272 320
WIRE 416 320 416 288
WIRE -224 352 -224 304
WIRE -96 352 -96 304
WIRE -96 352 -224 352
WIRE -592 400 -592 272
WIRE -448 400 -592 400
WIRE 0 400 -448 400
WIRE 16 400 0 400
WIRE 96 400 80 400
WIRE 224 400 224 304
WIRE 224 400 96 400
WIRE 512 400 512 384
WIRE 512 400 224 400
WIRE -224 416 -224 352
WIRE 352 416 352 288
WIRE 224 448 224 400
WIRE 64 480 -128 480
WIRE 80 480 80 448
WIRE 320 480 320 288
WIRE 320 480 80 480
WIRE -224 496 -224 480
WIRE -224 512 -224 496
WIRE -128 528 -128 480
WIRE -128 528 -160 528
WIRE -112 528 -128 528
WIRE -16 528 -32 528
WIRE 32 528 -16 528
WIRE 64 528 64 480
WIRE 144 528 64 528
WIRE 352 528 352 496
WIRE 352 528 336 528
WIRE 416 528 416 384
WIRE 416 528 352 528
WIRE 32 560 32 528
WIRE -160 592 -160 528
WIRE -160 592 -176 592
WIRE -112 592 -160 592
WIRE -16 592 -16 528
WIRE -16 592 -48 592
WIRE 144 592 112 592
WIRE -272 608 -272 320
WIRE -224 608 -272 608
WIRE 512 624 512 400
WIRE 512 624 336 624
WIRE -272 640 -272 608
WIRE 32 640 -272 640
WIRE 112 640 112 592
WIRE 112 640 32 640
FLAG 224 448 0
FLAG 304 48 0
FLAG 272 -80 Vout
FLAG -560 96 Vin
FLAG -448 400 Vinl
SYMBOL voltage -592 176 R0
WINDOW 123 0 0 Left 0
WINDOW 39 0 0 Left 0
SYMATTR InstName V1
SYMATTR Value SINE(0 350 60 0 0 0 10)
SYMBOL nmos 272 208 M0
WINDOW 3 -93 -12 Left 0
SYMATTR Value Si7802DN
SYMATTR InstName M1
SYMBOL ind2 -240 112 R270
WINDOW 0 32 56 VTop 0
WINDOW 3 5 56 VBottom 0
SYMATTR InstName L1
SYMATTR Value 100m
SYMATTR Type ind
SYMATTR SpiceLine Rser=20m
SYMBOL ind2 -128 0 R90
WINDOW 0 5 56 VBottom 0
WINDOW 3 32 56 VTop 0
SYMATTR InstName L2
SYMATTR Value 10µ
SYMATTR Type ind
SYMATTR SpiceLine Rser=100u
SYMBOL res 288 -80 R0
SYMATTR InstName R1
SYMATTR Value 100µ
SYMBOL voltage 512 288 R0
SYMATTR InstName V2
SYMATTR Value PULSE(0 10 10u 50n 50n 50u 100u 10000)
SYMBOL cap -144 176 R90
WINDOW 0 0 32 VBottom 0
WINDOW 3 32 32 VTop 0
SYMATTR InstName C1
SYMATTR Value 10n
SYMATTR SpiceLine V=600 Rser=0.5
SYMBOL ind -496 112 R270
SYMATTR InstName L3
SYMATTR Value 5µ
SYMBOL cap -416 176 R90
SYMATTR InstName C2
SYMATTR Value 200µ
SYMATTR SpiceLine V=600 Rser=50m
SYMBOL nmos 0 448 R270
SYMATTR InstName M2
SYMBOL ind 16 -64 R270
SYMATTR InstName L4
SYMATTR Value 1µ
SYMBOL diode -112 240 R0
WINDOW 3 25 63 Left 0
SYMATTR Value MUR460
SYMATTR InstName D3
SYMBOL diode -128 320 R180
WINDOW 0 24 72 Left 0
WINDOW 3 119 41 VRight 0
SYMATTR InstName D4
SYMBOL diode -240 240 R0
WINDOW 3 115 -36 VRight 0
SYMATTR InstName D5
SYMBOL diode -256 320 R180
WINDOW 3 24 0 Left 0
SYMATTR InstName D6
SYMBOL nmos -176 512 M0
SYMATTR Value SPA11N60C3
SYMATTR InstName M3
SYMBOL voltage 32 544 R0
SYMATTR InstName V3
SYMATTR Value 10
SYMBOL res -128 544 R270
WINDOW 3 0 56 VBottom 0
SYMATTR InstName R2
SYMATTR Value 100
SYMBOL res 336 400 R0
SYMATTR InstName R3
SYMATTR Value 500
SYMBOL cap -48 576 R90
SYMATTR InstName C3
SYMATTR Value 0.1µ
SYMBOL cap 400 320 R0
SYMATTR InstName C4
SYMATTR Value 0.1µ
SYMBOL res -240 400 R0
SYMATTR InstName R4
SYMATTR Value 0.01
SYMBOL Optos\\CNY17-3 240 592 M0
SYMATTR InstName U2
SYMBOL res -448 -96 R0
SYMATTR InstName R5
SYMATTR Value 1000
TEXT -360 56 Left 0 !K1 L1 L2 1
TEXT -384 504 Left 0 !.tran 50m
