B
Branden Faulls
I am trying to build a simple circuit with 2 flashing LEDs drawing power
from a USB power source. I am using 5mm LEDs with an integrated flashing
circuit from Maplins.
(http://www.maplin.co.uk/Module.aspx?ModuleNo=35804&TabID=1&WorldID=&doy=26m8).
The spec sheet for the LEDs says they have an operation voltage of 3.5 -
14V and a forward current of 20mA each.
(http://www.maplin.co.uk/Media/PDFs/QY96.pdf)
Since these LEDs can operate between 3.5 - 14 then I assume that they will
be fine at the USB's 5V 500mA. Is that right?
Similarly, since they can take variable voltage, will I need a resistor in
this circuit? My assumption was no.
Is the following a safe way to wire these?
V+ -+-[LED]--gnd
+-[LED]--gnd
How safe will the USB host bus be? I don't want to fry a motherboard with
my first project!
I'm a total beginner and I have tried to pick up as much from the other
LED posts in the group, but I'm not confident enough to build this without
some advice. I am especially confused how the 20mA
of current for each LED relates to the 500mA of the USB.
Thanks for any help
Branden Faulls
V+ -+-[LED]--gnd
+-[LED]--gnd
my first project!
Thanks for any help
Branden Faulls
