P
Peter E. Orban
Happy New Year to Everyone!
I have two TVs with vertical problems.
The first one is a Toshiba CM915C ch# 8516, with the lower 15% of the
picture folded back.
I built an ESR meter during the break (555 timer and scope), and found
and replaced a number of electrolytic caps in the vertical stage. It did
not help. I also replaced the vertical IC (AN5515) from another TV,
still the same problem. Anything else to check? I will go through the
other components if someone could give the values for those. Anyone has
access to the schematics, the sample application circuit on the AN5515
data sheet seems to be different than the one used in that particular
TV?
The other TV is a Mitsubishi CS21SX1C ch# XL-B-CSX1, with no vertical
deflection. Nothing seems to be fried visually, the caps check out ok
for ESR, no obvious sign of leakage. What is the vertical IC used in
that TV? It is a 13 pin SIP IC, and no number on it. Again, I do not
have a schematics, and finding a data sheet on that IC might help
diagnosing the problem (the yoke is not open).
Thanks for the help,
Peter
TV?
Peter
