What could be the cause of vertical lines at the screen of a Vizio tv?
Benny7440
Jan 14, 2016
88
Jan 14, 2016
88
The sound and other functions seem to be ok. Below I',m sending a photo of the screen as a sample of the problem.
Harald Kapp
13,719
13,719
Possibly one or more defect column driver chip(s) on the LCD. Or contact problems in the connection between LCD and mainboard.
davenn
14,260
14,260
This is a problem I see very often on LCD panels. Mainly smaller panels and in every case it has been the LCD panels at fault
quite possibly for the reason Harald stated
cheers
kellys_eye
Jun 25, 2010
6,514
Jun 25, 2010
6,514
Chip-on-flex issue..... my laptop does it now and again! A 'press' along the edge of the display often cures it - sometimes for minutes, sometimes for days. I'm looking for a new screen for a permanent fix.
Harald Kapp
13,719
13,719
I've seen semi-permanent solutions using elastic foam to exert the required pressure once the screen is reassembled.
