B
Bob Monsen
WilliamH said:Tom Biasiwrote:
message I want to make a flood light on the side of my house come on when a
circuit is broken.
I want to attach a low voltage wire to something in my front yard.
When someone tries to remove that something from my yard (they'll
have to cut the wire), I want my flood light be activated to scare
them off. I can't imagine this is too difficult a job for someone
that works in electronics. Can anyone tell me how to do this?
William
Hi William,
As is often the case people here read into the question before they
answer.
I am no different. I could just describe a circuit to do what you ask
but
feel compelled to but in.
If someone cuts the wire to steel your object the light will make them
run
alright, but with your object.
Why not just let the PIR floodlights come on when they get near the
object?
OK TOM, mind your own business! Someone steeling your statues
William?
Regards,
Tom[/quote:6719e5ad73]
Thanks for the response Tom.
Actually, someone is stealing solar lights from several of my
neighbors. I only found this out after purchasing some really
expensive ones. I don't want mine to be taken. I'm actually going to
anchor each light to the ground by a cable at the base of the light
(the lights are on 18 inch metal poles) attached to a piece of rebar
driven into the ground. On a first attempt, this will probably keep
the lights from being stolen. I'm sure they would bring wire cutters
the next time though. I want to sound an alarm and or light as the
light is pulled from the ground. I know this sounds elaborate, but
it's the principle at this point.
Thansk,
William
I wonder if you could build a tiny motion detector, that was powered by
the battery in the light? Any attempt to move it would cause the thing
to shriek for a few minutes. That way, the thief would be disuaded from
actually running with the item.
How cheap would it be to do this? I know it's pretty easy to build these
from an electret microphone and a few opamps, but there is probably a
ready-made solution out there you could just buy and wire in. Also, the
sensitivity would be an issue, I guess.
