Electronic trip wire / alarm
Discussion in 'General Electronics Discussion' started by Jimmy Deacon, Jul 20, 2017.
  1. Jimmy Deacon
    Jimmy Deacon
    Jul 20, 2017
    Hi people,
    Just looking for a bit of advice for a project I'm in the early stages of planning. I'm a total newbie so if we can keep things relatively simple it would be greatly appreciated.
    So essentially I want to set up an electronic trip wire (beam) hooked to an alarm and I want some suggestions for which components to use and why. Below are a list of requirements and wants for the system
    - The beam should be invisible (i.e. infra-red or ultra sonic)
    - The beam must be safe for eyes
    - The length of the trip wire must be adjustable between at least 1-4m
    - The sensor must be capable of integrating with an Arduino or similar programmable device. The intention being to set up multiple trip wires and then trigger different responses based on the order in which they are tripped i.e. two beams side by side and if you cross them in one direction the alarm sounds, but in the other direction no alarm (also the beams may only be 40mm apart)
    - Ideally the transmitter of the beam and the sensor will both be located at the same end (if necessary the sensor or a reflector could be located opposite the transmitter)
    - Reliable, but cost effective as I'm considering between 3-4 beams
    I hope this all makes sense,, let me know is a diagram would be helpful.
    Many thanks
  2. shrtrnd
    shrtrnd
    3,821
    519
    Jan 15, 2010
    Just for clarification, when you talk about a 'trip wire', you mean the beam itself, correct?
    Or is there some physical 'wire' you're talking about?
  3. Externet
    Externet
    761
    166
    Aug 24, 2009
    davenn likes this.
  4. Jimmy Deacon
    Jimmy Deacon
    Jul 20, 2017
    Correct, the energy beam is the metaphorical trip wire. There is no physical trip wire.
  5. davenn
    davenn Moderator
    13,833
    1,950
    so follow externet's very good advice
