Sir andomando. . . . . . .
Those RCA numbers made me go back to the '80's and consult some of my design reference books from that time frame.
I am now wondering if your amp unit is made along these manners that RCA used back then.
If so, then your RCA 1C03 and 1C04 would be used as complementary driver transistors to the RCA1B06 output transistors.
INITIALLY RCA made that unit using metal cased transistors, with TO-3 metal cased output transistors and either TO-66 or TO-39 metal cased driver transistors.
Then the economy transition to using plastic transistors . . . .2N5840's for the outputs and 2N6293 and 2N6476 JEDEC series of transistors for the drivers.
FINALLY they digress to using the 1C03 and 1C04 series that you refer to.
The 2N . . .JEDEC . . .series are still available if you just seek them out.
The already suggested . . . . .TIP 31C and TIP41C have their matched PNP complements of TIP 32C and TIP42C, but are a bit WEAK in the hFE spec.
The logical next TIP choice would be the TIP 147T and TIP 142T but their hFE spec, possibly might be too high up in the 500+ range.
The ECG series straddle across the lower 15-150 hFE spec
TECHNO REFERENCING:
(MAG it on up . . . .it gets reeeeel beeeeeeg)
Thasssit . . . .
73's de Edd
