C
colin
John Larkin said:That will be an asymmetric non-50 ohm impedance, and proper TDR needs
a true 50 ohm source; most electrical TDR is done with a step, not a
pulse. But you don't need a lot of voltage - 0.25 volts into 50 ohms
is standard - so you can pad down a 5-volt swing and get a very good
50 ohms.
You only need matched termination for when the pulse returns,
by wich time the transistor will be fully off.
ofc this rules out using a step.
Most ethernet chips have TDR built in for coax connections anyway,
even most PC ethernet ports have this feature,
although its probably quite hard to find any software that can access it.
Another good way is to use a single frequency at anyone time,
and measure the standing wave voltage,
thus avoiding any pulse smearing,
to give absolute distance the frequency is scanned untill it passes through
2 nulls.
all it needs is a 1-2ghz vco and a PIC.
Colin =^.^=
