C
Chris W
I would like to thank everyone for all the help over the past little
while. I thought I would share the results of that help.
http://www.thewishzone.com/LightController/
I have put together my 256 light controller on prototype boards. Right
now it only controls 32 lights. It is expandable in 16 light
increments. It is made up of 3 basic parts. First there are up to 16
"Light boards", each will be stackable and control 16 lights. Then
there is the light board addresser. That will be on a PCB with the
micro controller and it will send a signal to each of the 16 light
boards. Finally the micro controller. I decided on the Rabbit
RCM3100. I know it is over kill, but I wanted to be able to program it
in C. Here are the details.
The "light boards" each have a 4 to 16 line decoder (CD74HCT4514) and 16
D type flip flops (SN74HCT74) wired up as toggle flip flops. All of
the, up to 16, light boards have the 4 LSB from an 8 bit output on the
RCM3100 hooked to the input of the 4 to 16 line decoder. The output of
the flip flops will go to either solid state relays or a transistors of
some kind to drive higher current loads.
The light board addresser has a slightly different 4 to 16 line decoder
(CD74HC154) the out puts of which go low instead of high. It gets it's
input from the 4 MSB of the 8bit output on the RCM3100. It's 16 outputs
each go to the enable input on the one of the CD74HCT4514s on the 16
light boards.
I can then program the RCM3100 to flash the lights in any pattern I can
dream up and I have dreamed up quite a few already. Of course I now
need to layout a PCB and have some made. First I need to design the
circuit that the RCM3100 will go in, with some kind of power supply
regulator and a few buttons to select different modes. The prototype
board is way too big for what I want to do with this other wise I could
just solder on a pin header and hook my boards to that.
The final result will be a remote control airplane that will be lit up
in manor that will put any Christmas tree to shame. I then plan to have
some fun flying it at night. The reason I want to have the lights flash
in all kinds of different patterns, is I intend on using the flashing
pattern as well as the LED colors to help keep track of the orientation
of the plane. Of course there is also the "cool factor"
Chris W
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
http://thewishzone.com
light boards.
Chris W
