Jelleyzeefirst
- Jun 7, 2017
- 1
- Joined
- Jun 7, 2017
- Messages
- 1
Hi guys,
I'm trying to build a circuit that i can measure the continuity of a L.E.D (red), while being able to turn that L.E.D on and off. I also don't want to set it off while testing if its there. I decided to do this using a voltage of 1volt through the red L.E.D while off and 5v when turned on.
Then have that 1volt go into an op amp (741) with a feedback resistor and for the output to turn on a green L.E.D. So the green L.E.D should only go off when there's no red L.E.D in place.
I only have a battery pack of 3AAs so I've used 2 voltage dividers to get 1volt as well as +4.5volts (close enough).
The only problem is i cant get the circuit to work like this. I've tried 2 different op amp chips and i had the same problem, the green L.E.D stays on no matter what. With the out pin and inverting pin stuck on about 1.8volts.
I don't know why my circuits behaving this way or if I've just screwed up the design badly, but any help would be much appreciated
