Hi
Total noob here but very willing to learn.
I after some much needed help, I have searched and searched and have come close to what I am after but always seem to be not quite there.
So here I am after your help.
What I want is a simple and effective way of controlling a cooling fan on my car engine.
Thats quite simple, yes if you want the fan to swith on and off.
But I don't.
I want the fans speed to be controlled by a pwm.I already have the pwm.
Here is the tricky bit.
I want the fan to start at a low rpm and increse up to its full speed as the temperature of the engine rises.
ie at say 89'c the fan should start and at 97 the fan should be a full speed.It would be good to have a pot to enable me to trim the control.
The fan is 80 watt.
The pwm can have a input voltage of 0-5v dc
Is there already a circuit I can use or could someone point me in the right direction.
Many many thanks
But I don't.
The fan is 80 watt.
Many many thanks
