Switch question.
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
The ones above do that, they are called momentary switches, same as your link.
Adam
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
I am not sure how they work inside but that is what I would order if I wanted a switch to spring back. Unless they have named it incorrectly.
Adam
HellasTechn
Apr 14, 2013
1,579
Apr 14, 2013
1,579
Yes adam. This is very likely with many chineese sellers on e-bay. I will send them an e-mail to make sure.
So they are just called momentary switches.
Thank you.
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
Yes, they often use the term MOM for momentary.
Adam
Minder
Apr 24, 2015
3,479
Apr 24, 2015
3,479
SPDT momentary.
Single pole double throw momentary toggle switch.
M.
HellasTechn
Apr 14, 2013
1,579
Apr 14, 2013
1,579
Well what you say makes sense but after looking at the diagram of the switch i dont see any "return spring" inside it.
shouldn't there be one ?
Here is my question:
Good day.
Does the switch lever go back to initial position after released ?
Thank you.
Ok here is the seller's answer :
the actual item is the same as the picture and item description shown on ebay.
pls check again to see if it's the item you really want,ok?
Can you trust a seller that gives this answer? while listing says momentary and description says SPDT On/On 2 Position Toggle Switch.
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
Ummmm..... I would try and get them from RS or Digikey and check the data sheet. EBay can be a bit of a pain, that's why I don't use them anymore. I prefer Amazon personally.
shrtrnd
Jan 15, 2010
3,876
Jan 15, 2010
3,876
Sounds like you 'talked' to a salesperson, not somebody who actually knows what the switch is.
From the description the seller supplied to you, it sure doesn't SOUND like a momentary switch.
I'd look elsewhere.
I've seen some catalog descriptions mention, 'retrun to center', when they describe their momentary
switches.
Minder
Apr 24, 2015
3,479
Apr 24, 2015
3,479
It sounds like it is a 2 posn (non sprung return)
The two types are MOM (spring return) or maintained, I suspect the ones in the original post are maintained.
BTW there are also the Telemecanique ZB2 series operator button type you can get them in several configurations, they now sell them on ebay out of China cheap. If these will work for you?
M.
