Dave.H
I need to replace a 1.2 uF electrolytic capacitor, and the closest I
can find is 1.0 uF. Is it OK if I install this one?
Dave.H said:I need to replace a 1.2 uF electrolytic capacitor, and the closest I
This is probably a stupid question, but what value should the second
capacitor be? The power supply is 240 volts, I can only find a 350
volt electrolytic. I've heard the electrolytics don't like too low a
voltage, would this still work?
Capacitors add in parallel, so a 1uF in parallel with a .2uF makes up
1.2uF.
Dave.H said:Another stupid question, but would I be able to use two .01 capacitors
in parallel with the electrolytic? I can't seem to find any .2 caps.
20 times a 0.01 , yes.
2 times a 0.1, off course!
Best regards,
Daniel Mandic
Sorry, I don't understand what you are saying. Please excuse my
almost non existent knowledge of elctronic circuits, I'm still
learning .
default said:Sure. Many electrolytic's are specified at +200% to -20% capacity
(common aluminum types in particular)
The capacitor is of the old
metal cased type, made in 1966, installed in the base of an old electric
fan.
----------------------------------------------------------------------------------------I need to replace a 1.2 uF electrolytic capacitor, and the closest I
Are you sure you mean +200% ? More like +50% max I'd have thought in the case of
electrolytics.
Graham
The context of your problem isn't clear, but since elec caps have at
best +-20% tolerance,
Use 0.22
0.2 isn't a standard value (except from some ancient US suppliers).
