You wrote, ". . . but I've never found a way of doing anything useful
with this circuit."
If as you wrote in the paragraph after that, you put it in series with
a resistor, you get a circuit that behaves much like a series resonant
circuit. Not only does it go through a phase inversion, but it goes
through zero resistance. Similarly if you put it in parallel with a
resistor, you get something that behaves much like a parallel resonant
circuit: where the gyrator negative resistance equals the parallel
positive resistance, the net resistance goes to infinity. If you think
of C-R-L circuits (or better, 1/sC, R, sL) as having components that
contribute in quadrature, with 90 degrees going from C to R and R to L,
you see that you can have the same effect with three components that
behave as R, sL and s^2Gyrator; you've just multiplied everything by s.
Or you can have a {1/s^2Gyrator, 1/sC, R} set. And you can expand
your filtering horizons by having a set {1/s^2Gyrator, 1/sC, R, sL,
s^2Gyrator} . . . that lets you implement higher order filters in
simpler topologies (if only the gyrator were a simple passive two-lead
part!)
Gyrators don't seem to be used very often, but I have seen them used to
(presumably) keep the op amp out of the direct signal path, in an
attempt to have it contribute less distortion in the passband.
Cheers,
Tom
That's an FDNR, (Frequency Dependant Negative Resistor), and can be realised
with the basic four-op-amp gyrator circuit using two capacitors and three
resistors. You can get a negative resistance that either increases or
decreases as the square of the frequency, depending where you put the
capacitors, but I've never found a way of doing anything useful with this
circuit.
You can make a frequency dependant voltage divider with an FNDR and a
resistor, but the circuit goes through a phase inversion, the point of
inflection being at the frequency where -R = R
Check out the Sept 14 EDN Magazine, "design ideas" Brick-wall lowpass audio
filter for a practical circuit which uses three gyrators.
I don't care much for EDN, but occasionally a contributor sends them
something really good. This is one.
Don
