Static IP address
Discussion in 'Off-Topic Members Lounge' started by juh, Apr 5, 2013.
  1. juh
    juh
    27
    Feb 21, 2013
    I don't know where to put this thread. :eek:
    How and where can I get a static IP address? We just installed a CCTV system with a DVR and we want to view or connect with it remotely, but our ISP uses DYNAMIC IP. Did I explain it right? Hehe
    My boss just asked me to research about it. Thanks!
  2. (*steve*)
    25,497
    2,838
    Talk to your ISP.
    However there are alternatives. Google "dynamic DNS"
  3. juh
    juh
    27
    Feb 21, 2013
    It's the first time I've heard of that but I think it can solve our problem. Thanks a lot!
  4. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    www.noip.com works well for me, I have been using them for maybe 10 years now... Heck the client is even built into my new router, makes it dead simple...
  5. juh
    juh
    27
    Feb 21, 2013
    Thanks! Tried it, it works!
  6. juh
    juh
    27
    Feb 21, 2013
    Hello. I have another question. How can I install no-ip DDNS if my DVR is directly connected to the modem? Thanks!
  7. (*steve*)
    25,497
    2,838
    The easiest way is to get a router that handles DDNS.
    By modem, I assume you're talking about an ADSL/Fibre/Cable modem, not dialup?
    Alternatively, you could also connect a small PC to another lan port. Some are very tiny. (These run a version of Linux, and you need to know how to flash them to run DD-WRT (free software) if it's not already loaded).
  8. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    I have nothing but good things to say about the TP-Link TL-WR1043ND...
  9. juh
    juh
    27
    Feb 21, 2013
    I have a wireless router, i'll just use that. Now, my issue is port forwarding. My DVR has ports for HTTP, UDP, TCP and Talk. Shall I forward all those? This is my first time dealing with this. Thanks for your help.
  10. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Not all routers will update the DDNS info, thus if your ISP changes the IP and you don't update the system fails... If your router does not support DDNS updating then you will need to have another computer that is on the same connection do the updating for your...
    Yes, forward all ports used by the DVR to the DVRs local IP... Make sure to give the DVR a reserved static IP number...
  11. juh
    juh
    27
    Feb 21, 2013
  12. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    Looks like you router supports DDNS so you should be good...
    Yes, sometimes the best way to do it is to set your DHCP sever on the rotuer to a range like 192.168.1.0 to 192.168.1.100, and then if you can manually set your DVR IP force it to something outside that range like 192.168.1.111... This way there is no chance that the DHCP sever will burp and have an IP conflict or issue... If you can't manually lock the DVR into a force IP, make sure to reserve said IP to the DVRs MAC address so that the DHCP is supposed to give that IP to the DVR... Note, I say supposed because it's been my experience that if for some reason the device drops signal for a bit due to a brown out or signal interference, it will try to log back onto the network but the DHCP gets grumpy for whatever reason and won't let it right away...
    I had to do this with my WD Live TV units because they network kept hanging, force the IP outside the DHCP range and all is good...
