Anyone have any ideas for a creating a very stable 0.5 VDC reference, with
an minimum of board space? The best idea so far has been a higher voltage
reference followed by a resistor divider and a buffer, but the stability
(less than 0.1%) isn't there.
IC references are available with stability <20ppm for constant
temperature situations. (I assume accuracy isn't important, or there
would have been some decimal places in the voltage.)
Divider resistors can track with similar stability.
Buffer offsets are limited only by what you want to pay, but you could
use an integrated circuit like the LM10, with an internal reference
and op amp, with an external transistor in the loop to remove
load-sensitive self-heating.
Then you could intentionally regulate the IC temperature using the
self-heating effect and a PTC parallel load. This would give long term
stability similar to oven-heated references, if the mechanical
environment was stable.
Other effects have to be approached as needed.
If it had to be SMD, I'm sure the same principals could be applied to
other devices.
RL
