firsttimer
- Mar 6, 2015
- 1
- Joined
- Mar 6, 2015
- Messages
- 1
Hello all. I'm hoping someone can point me in the right direction on switchs.
basically ill have a 9 volt system, that i need a switch for. It will only have 1 input and 1 output. simple right?
Ill have a pressure sensor sending a 0- 5.0 volt signal to the switch. I need a switch that is adjustable (simple incorporated rheostat should do it i would think), I'll be taking the signal from the pressure sensor and I need to set at what voltage it will trigger its output (basically matching up what P.S.I correlates with what voltage output of the sensor).
A link would be fantastic! Thank you all for your help.
