Sony DVD player update
Discussion in 'Electronic Repair' started by Golf, May 23, 2007.
  1. Golf
    Golf Guest
    I am finally able to see the replies to my post (posted twice because
    I thought the first didn't make it). First, thankyou to all that
    replied, especially about the usenet being screwed up. Now I know it's
    not my account or computer. Anyway, yes, I had the DVD player
    connected through my VCR. I bought an Orion TV a few years ago (yes,
    it's a peice of garbage but it works), and it only has one set of RCA
    inputs. Currently these are being used by my sattelite receiver. I
    disconnected this and routed the DVD player straight to the TV as
    suggested, and what do you know - it works perfectly. I don't quite
    understand the macrovision issue being a cause to the problem. I could
    somewhat understand the digital to analog having an effect. Well, I
    must say I feel like an idiot for not even thinking about this as
    being a cause. I had to look to see if this is how I hooked it up!
    Thanks for the replies and as usual the problem was pointed out. Now I
    like my Sony DVD player! Thankyou!
  2. jakdedert
    jakdedert Guest
    Buy a switchbox. They're cheap...or make one.
    jak
  3. Arfa Daily
    Arfa Daily Guest
    The MacroVision is an issue to stop you being able to analog-record a
    commercial DVD onto a videotape, potentially making it a 'pirate' copy. It
    inserts high level bursts of pulses onto the sync pulse porch level, which
    most VCRs - the old Sony Betamax machines being a notable exception - use as
    the reference level for the AGC clamp circuit. The bursts of pulses make the
    average level shift, which in turn causes the AGC clamp level to shift,
    which results in the cyclic brightness level shift that you see. As others
    have commented, just get a manual or automatic scart multiplier box.
    Arfa
  4. Andy Cuffe
    Andy Cuffe Guest
    I hate macrovision. All it does is interfere with honest people who
    actually bought the original DVD. It affects the sync on my video
    projector which is only 3 or 4 years old. Can someone explain to me
    why they insist on adding macrovision to the progressive scan output
    of a DVD player? No VCR can record progressive scan video. It's
    ironic that the best way to get around this problem is to make a copy
    of the DVD.
    Andy Cuffe
  5. Golf
    Golf Guest
    Thankyou for the info. Now I understand why this was happening. But
    pardon my ignorance, what is a "scart multiplier"?
  6. Arfa Daily
    Arfa Daily Guest
    Just a box that multiplies the number of scart connectors available to you.
    A typical "cheap 'n' nasty" manual one might have two or three scart
    connectors on the top of the box, a two or three way switch, and a short
    flylead with a scart plug on the end. Fine for the occasional need to take
    output from a source that's alternative to your 'normal' hook up. Better
    ones make use of the scart switching signals, and can automatically route
    the needed scart source to its output, with no intervention from you being
    required.
    http://www.maplin.co.uk/Search.aspx?criteria=scart box&source=15&SD=Y
    This is a UK site, but it will show you the sort of stuff available, and you
    should be able to get similar in the US. I'm pretty sure that I've even seen
    them in Walmart when I've been there.
    Arfa
  7. Gary Tait
    Gary Tait Guest
    That is if one has SCART. It is rare for equipment in the US market, where
    the OP is from, to have SCART.
    SCART, for the edificatino of the OP, is a one connector and cable system
    for interconnecting A/V devices, typicaly in Europe and other places PAL is
    used. For some odd reason or another, it was never introuced into North
    America.
  8. Gary Tait
    Gary Tait Guest
    Macrovision messes with the AGC of VCRs to prevent piracy, creating an
    unwatchable copy.
    Unfortunately, some VCRs have the AGC on the video input, rather than the
    video record, which makes them not useable for RF modulators for DVD
    players.
  9. Arfa Daily
    Arfa Daily Guest
    Yes, Gary - you're quite right now I come to think of it. It also gets known
    as a Euro connector, which is of course a dead giveaway - although I'm sure
    I have seen scart accessories in Walmart over there, but I could be wrong on
    that point. Absolutely everything is connected that way here, and it's a
    very convenient way of doing it, and works well once you get your head
    around it. As well as the video and audio signals both ways being available
    at the connector, there are also switching control lines, where devices in
    the chain can control the signal paths between each other. So if you pop a
    disc in your DVD and just hit play, it will inform the TV that it is looking
    for access, and the TV will respond by automatically switching to the input
    that the DVD is connected to, and so on. It's beginning to be superseded by
    HDMI now, which I think is a bit more world wide.
    Arfa
  10. Gary Tait
    Gary Tait Guest
    You may have seen V-port, or some other game console specific connector.
    The only Scart I've seen is in some imported DVB satellite receiver or
    perhaps DVD palyers. Equipment mass manufactured for the US market just
    doesn't have SCART installed. I have seen empty spots on boards for
    SCART connectors though, in some gear.
    Yes, HDMI is being incorporated into new digital sets and set top boxes.
