The (older) ones I have switch the secondary so you are just seeing
transformer losses. I don't know any reason why the primary could not be
switched. Also, I find the report of bad cable killing solid state devices
pretty remote. Even a lose connector will cause the unit to shut down and
require reseting the power to get it back on again. They monitor the vswr
for faults.
Everything in my lab runs off two big Isobars--I just flip them off when
I leave the lab. At some point I need to install a 12-way splitter and
distribution amp on my Rb frequency standard so I don't have to wait for
all the 10811As in my HP boat anchors to warm up.
Why not slave everything to one of the boat anchors. Don't they keep power
supplied to the OCXO when off? At least the 856x does. They all have an in
and an out for their clocks as far as I remember. Then you just need to keep
power supplied to that device.
The Rb should always be powered as it takes a long time to fully reach a
stable equilibrium. But maybe your requirements are not that demanding.
Next you should get one of the Trimbel Thunderbolts for < $200 and have a
GPS traceable reference.
tm
