S
Sidney
Sharp 4 head hi-fi stereo vcr model:VC-H988U,year:Nov 98,CSA file #
LR96163=Funai/Symphonic,the white plastic slide bracket underneath the
vcr located right of the cam gear and behind the both tape guide post
guide gears is broken and I need a part # for it.
Again I need the part # for the slide bracket(idler plate) also any
OEM part #'s for it,I looked in all of the part # look up sites below
and only Tritronics had tons of parts for this unit but alot of the
parts were labeled as "slide brackets".
Thanks for your time and effort.
http://www.tritronicsinc.com/lookup_cs.htm
http://www.wehaveparts.com
http://www.partsolver.com/Default.asp
http://atv.partsearch.com/search.asp
https://www.vancebaldwin.com
http://www.mcmelectronics.com
http://www3.sears.com
http://www4.sears.com
http://www.radioshack.com/ProdSupport/ProductSupport.asp
http://www.radioshack.ca/en/templates/partlist.asp
http://www.timelapsesupply.com
Note:it is not Sharp part # MSLIF0076AJFW=$15.57 CDN as I just
received it from Sharp Of Canada by Purolator (2 day ground
delivery),the part that arrived is the metal plate for the carriage,so
it is the wrong part.
Sidney
E-mail:[email protected]
Dartmouth,Nova Scotia
Canada
Sidney
Canada
