P
Patrick Timlin
Here is something I am thinking about that I am not sure of the
answer. Normally when you decouple something you use a single cap, but
what if you needed a value you didn't have but instead had twice that
value and series connected them to get the desired value?
Theoretically you get the value you need, but in real life, does a
series connection of two caps still give you decoupling?
The real life data... for a product we have a real time clock running
off a 32768 crystal, pretty standard stuff, but we have an issue with
the clock gaining time. This is for a Motorola PowerPC based design
and Motorola acknowledges certain problems with thier chip that can
cause this. One suggestion is to add a 10pF cap off the XTAL pin to
ground in addition to the normal crystal circuit. So I find I don't
have 10pF caps around, but do have 18pF caps, so I figured two of
these in series gives me 9pF, close enough. These are also 0603
ceramic chip caps and found a way to mount them so that I don't need
to add any additional wires (the two caps nicely bridge across the
point I need them and a ground point) so no added inductance due to
wires.
Anyway, I am letting it run to see if it still gain time, but I
started thinking if the series of two caps is really valid for
decoupling like this. I will try just a single 18pF if this doesn't
work, but thought I would throw it out for discussion to see if anyone
might know for sure about this situation. Like I said I never really
gave it much thought since I never had a need to do this in the past,
but now that I am thinking about it, I am wondering if this is one of
those "real life does not match theory" kind of things where my "9"pF
won't look like a single 9pF cap in this sort of situation. Thoughts?
PT
wires.
PT
