Electrolytic caps in series
Discussion in 'Hobby Electronics' started by Rheilly Phoull, Jun 22, 2005.
  1. Mark Harriss
    Mark Harriss Guest
    You haven't seen my cat then: a very hairy date!!
  2. What you do is calculate the bleeder resistor value based on the
    following worst case conditions:
    - The maximum voltage rating of one one of the caps
    - Assuming one cap has maximum leakage and the other has zero leakage
    i.e. The capacitor with the leakage with drag the mid rail voltage away
    from it's nominal half rail, creating a greater voltage across the cap
    with no leakage. You don't want to have more than the maximum capacitor
    voltage across the non-leaky cap.
    Once you assume these worse case conditions then the circuit is easy to
    analyse.
    Each resistor is:
    R=(CapLeakRes * (MaxCapVolt-(Vrail/2)) / (Vrail-MaxCapVolt)) * 2
    The leakage will be voltage dependant, but this a simple way to look at
    it.
    Hope that helps.
    Regards
    Dave :)
  3. Phil Allison
    Phil Allison Guest
    "David L. Jones"
    ** The scenario concerns *identical, new electro* caps being used as post
    inductor filters.
    ** Why not assume the earth is flat while you are at it??
    ** You forget the caps are in series - so any current MUST be identical
    in both caps at all times !!!
    ** I got news for you David - if an electro shows little or no leakage,
    then it is well able to stand the applied voltage.
    ** Shame all your assumptions are false.
    ............ Phil
  4. Phil Allison
    Phil Allison Guest
    "Uncle-Fester" = another anencephalic prick
    ** **** off - you rote learning moron.
    ........... Phil
  5. It's called calculating for worst case conditions, it's a perfectly
    valid way to calculate bleeder resistors.
    Not when you put bleed resistors across them! That's what we are
    talking about.
    If the leakage of a capacitor changes then the mid rail voltage will
    change also, thus increasing the voltage across the other cap. It ain't
    a simple series circuit any more when you put bleeder resistors in
    PARALLEL.
    Bleeder resistor values are always calculated using ball-park figures
    and typical expected worst case conditions. In this case one cap could
    be leaky and the other cap may not have any leakage, how is that a
    false way to view this circuit?
    The question was how to calculate bleeder resistor values for series
    caps, not if they are needed or not. I gave an answer for calculating
    bleeder resistor values, how would you calculate it Phil?
    Dave :)
  6. Phil Allison
    Phil Allison Guest
    "David L. Jones"
    ** No electro has zero leakage and the "maximum" cannot be found except
    by testing a huge number of caps.
    ** Not with your totally mad assumptions.
    ** Learn to read David, the current flowing in series connected caps must
    be identical.
    ** Go back - you have jumped a crucial step.
    ** Correct - the problem is your assumptions about these matters are
    wacky.
    ** Zero leakage electros do not exist.
    You are pulling wild assumptions out of mid air.
    ** The two questions are not separable.
    You need realistic figures for the leakage performance and leakage v voltage
    curve of the ACTUAL caps in question BEFORE any calc can be done.
    ** You gave a ** bleeding stupid ** one - I doubt a *digital* person
    like you has ever worked on gear with more than a 15 volt supply in your
    life.
    Do you claim to have any engineering experience with high voltage electros
    ** My position is that the OP does not need any in **his** app - if done
    as I suggested with new, identical caps that have a 30 % or more margin of
    voltage.
    " ** Forget it - just use caps that have a large margin in excess of
    the
    needed voltage.
    Eg - two 350 volt types applied to a 500 volt supply.
    The caps will very soon reach a mutual, acceptable agreement on what
    precise voltage suits their individual taste !! "
    The reason I said this is that I have done it at least 100 times with 350
    and 400 volt caps from WES and Farnell and in every case the resulting
    centre voltage was within 5% of half supply.
    There are OTHER situations where bleed resistors might be very worthwhile or
    even essential - ie on the first stage after the rectifier where the caps
    may undergo significant ripple current and hence self heating.
    ............ Phil
  7. Yep, that's why the question is relevant and I gave a way to calculate
    the values, as asked.
    How you get the "worst case" or "best case" leakage values doesn't
    change the formula presented, or the way you calculate it.
    You still haven't told us how you would calculate the values Phil.
    Dave :)
  8. Phil Allison
    Phil Allison Guest
    "David L. Jones"
    ( snip lots of good stuff that DLJ rudely ignored)
    ** The OP has a specific case in mind - but being a novice he asked an
    overly general question thinking it would contain the answer he needed.
    NG posters do that over and over and over - then wind up with a totally
    useless answers from pedantic fuckheads like David L Jones who must
    **insanely** imagine he has been presented with an some problem to solve
    ** So you deny posting this ?
    " What you do is calculate the bleeder resistor value based on the
    - Assuming one cap has maximum leakage and the other has zero leakage. "
    ** The info you supplied is utterly useless to the OP as he has no idea what
    leakage figures to use.
    Apparently - since you are a digital tech using 5 volt supplies -
    neither do you.
    ** You rudely ignored what I posted on that question:
    " You need realistic figures for the leakage performance and leakage v
    voltage
    curve of the ACTUAL caps in question BEFORE any calc can be done. "
    You also need to know all about the application and determine if the DC load
    current of the bleed resistors is acceptable at all - in the OPs one,
    the original caps had no bleed resistors and additional DC current would
    significantly disturb supply voltage values and increase supply ripple so
    that it became audible as hum.
    ............ Phil
  9. Phil Allison
    Phil Allison Guest
    "Phil Allison"
    **correction:
  10. Franc Zabkar
    Franc Zabkar Guest
    Series caps are often used in dual voltage PSUs. Here is a typical
    circuit with balancing resistors:
    http://www.pavouk.comp.cz/hw/atxps.png
    - Franc Zabkar
  11. dmm
    dmm Guest
    Whilst others have given their ideas as to the values (and how they are determined)
    to be used, ensure that the voltage rating of the resistors exceeds the voltages
    expected across the capacitors, especially for the worst possible scenario,
    ie if a capacitor fails for some reason.
  12. Phil Allison
    Phil Allison Guest
    "dmm"
    ** You can't be serious ???
    Worry about some 10 cent resistor failing AFTER a high voltage electro has
    exploded ??
    In any case, it would only do if its power ratings were exceeded.
    ............. Phil
  13. One day Phil Allison got dressed and committed to text
    Thanks folks for all the info, I think I have the gist of it. Whilst I have
    not a great deal of theory I have a lot of exploded devices behind me :)
    I'm going along with Phil, that master of gentle explanation.
    Cheers........... Rheilly
  14. Phil Allison
    Phil Allison Guest
    "Rheilly Phoull"
    ** Hey, I'm doing real well this week - that is the third "back handed"
    compliment in a row !!!
    BTW
    Are you working on an old Fender guitar amp ??
    They are full of 20 or 22 uF @ 500 volt caps - sort of reddish brown
    coloured ??
    ............... Phil
  15. dmm
    dmm Guest
    Perfectly serious.
    Caps can fail for may reasons, not necessarily by exploding, but that is one of
    their more spectacular results. I remember many years ago having to clean the
    guts of a Radford valve power amplifier whose main filter caps had let go. What a mess.
    A resistor could conceivably cause a fire if it isn't specified properly and the correct
    value, voltage, and power ratings and deratings aren't correctly calculated and defined.
    When playing with high voltages it would be prudent to spec the resistor to be flameproof,
    or at least to have a flame retardant coating.
    If the leakage of one capacitor changed, the voltage across both bleed resistors would change
    as well, possibly exceeding their voltage rating.
    A standard MRS16 330K ohm 400mW metal film resistor across a 300 volt supply
    would not exceed its power rating (273mW), but would exceed its voltage rating of 200V.
  16. Poxy
    Poxy Guest
    I think being favourably compared to Rod Speed probably doesn't quite count
    as a compliment, forward- or back-handed.
  17. Terry Given
    Terry Given Guest
    Here is a front-handed complement: you are right.
    To design the balancing resistors, simply choose resistors that draw
    more than the leakage current, to swamp out the variations. how much
    more depends on how well the voltage needs to be balanced.
    Thats all well and good, but leakage current increases with increasing
    temperature, and the variation is extremely wide. So an effective
    balancing resistor is a fairly low value, and gets hot.
    Last time I did the calcs (Hitachi AIC caps), it was around 30k-40k. So
    I thought "?!" and looked at some existing product. which used 470k.
    which draw far less current than the *measured* leakage current of the
    caps at room temperature. voltage measurements showed DC balance was not
    great, and did not change when balancing resistors were removed. hardly
    surprising really.
    In addition, the balancing resistors affect only the DC voltage. AC
    voltage sharing is governed entirely by capacitance ratios. This is very
    important at power-on, when Vdc ramps from 0 to 100%, perhaps quickly.
    Its easy to calculate the dV/dt needed to draw more current than the
    balancing resistors, or the frequency at which Xcap < Rbalance. Any
    faster than that, and Rbalance does nothing.
    Cheers
    Terry
  18. Phil Allison
    Phil Allison Guest
    "dmm"
    "Phil Allison"
    ** More fool you - dickhead.
    (snip irrelevances)
    ** Hmmm - so I see you actually have no fucking idea what particular
    failure mode the voltage rating refers to.
    ( So you pulled in all those extraneous ones to cover that fact. )
    ** Obviously a Sea Food lover here - red herrings galore is a favourite.
    ** Just for fun - how about YOU tell all of US what failure happens
    ( and after what time span ) when a resistor is run somewhat beyond its
    rated voltage BUT well within its power rating.
    Then explain how a high voltage cap can fail ( either short or open) BUT
    and the gear keeps working for a significant time so is left switched on.
    Then explain why this matters to anyone ??
    ............. Phil
  19. Phil Allison
    Phil Allison Guest
    "Terry Given"
    ** Why even bother ????
    The two caps will sort it out between themselves - as long as there is a
    30%+ voltage margin.
    ** Correct - in many cases there is no need and no benefit at all.
    ** Some 56 uF, 400 volt caps ( WES HSW types) I tested today showed a
    leakage of < 2 uA at 250 volts, at room temp.
    This increased to a mere 10 uA when quite hot.
    The appropriate ballast resistor value is therefore about 20 Mohms.
    Forget it !!!!
    With 2 in series across 500 volts, the middle point read 265 volts.
    IME - this is how most modern electro caps behave.
    ................ Phil
  20. KLR
    KLR Guest
    I dont see why there is such a fuss about this really.
    If you have 2 caps in series, or if you have a single cap of the same
    value (as the series combination) across the rail why is the failure
    of ONE cap in a series pair some major problem, or somehow worse than
    the single capacitor failing in the same way and deserving of a lot of
    fuss and bother ?
    Either way, depending on the way it fails, (eventually either goes
    open circuit or short) you are going to have either an almighty bang,
    or a hell of a lot of hum on the rail that the cap is filtering.
    Either way the cap(s) is fucked
    I would just use caps in series, as long as they are same value and
    voltage rating everything should be fine. I wouldnt go mixing values
    and WOULD have a rating on EACH cap significantly higher than 50% of
    the rail voltage.
    I have done it before too on a few occasions, with no problems at all.
    Both on high and low voltage rails.
