Hi Which is the largest (in bits, not mm^3) serial RAM IC you guys know about? Thanks
T Tremendo Jan 1, 1970 0 Sep 4, 2007 #1 Hi Which is the largest (in bits, not mm^3) serial RAM IC you guys know about? Thanks
T TT_Man Jan 1, 1970 0 Sep 4, 2007 #2 Tremendo said: Hi Which is the largest (in bits, not mm^3) serial RAM IC you guys know about? Thanks Click to expand... Atmel serial flash, 64Mbits at45db611 ?
T Tremendo Jan 1, 1970 0 Sep 4, 2007 #3 Atmel serial flash, 64Mbits at45db611 ? Click to expand... Thank you, but I said RAM.
T Tony Jan 1, 1970 0 Sep 4, 2007 #4 I couldn't find any decent-sized serial RAM when I needed it, and ended up using RAMTRON's FRAM - 256k bits, which is non-volatile, but acts like RAM in writability, speed, power and lifetime. Tony.
J John Larkin Jan 1, 1970 0 Sep 5, 2007 #5 Hi Which is the largest (in bits, not mm^3) serial RAM IC you guys know about? Thanks Click to expand... You could program an FPGA to be a serial ram and get from a couple of hundred kbits up. But that would be a pretty weird thing to do. John
S Spehro Pefhany Jan 1, 1970 0 Sep 5, 2007 #6 You could program an FPGA to be a serial ram and get from a couple of hundred kbits up. But that would be a pretty weird thing to do. John Click to expand... How about a much smaller CPLD to turn some other kind of RAM into a serial RAM. Best regards, Spehro Pefhany
M Mike Harrison Jan 1, 1970 0 Sep 5, 2007 #7 Hi Which is the largest (in bits, not mm^3) serial RAM IC you guys know about? Thanks Click to expand... found this a while ago http://www.nanoamp.com/news.html However I think they got taken over & not sure if this product is actually available.
