Serial Communication with dsPIC30F4011
DJPat
Nov 4, 2016
Nov 4, 2016
Hi..I've been trying to get my serial communication on the dsPIC to work. I need to be able to transmit and receive at least one character but all I seem to get is an junk transmission. I'm not sure if my code is right. I've tried a max232 circuit and an off the shelf usb-to-serial bridge. Both give the same output. I've also made sure the baud rates are correct. Please help.
Here's my code:
//------------------------------------------- Defines
#include <p30f4011.h>
#include <xc.h>
#include <libpic30.h>
#include <ports.h>
#include <dsp.h>
#include <math.h>
#define FCY (unsigned long) 30000000 //add your operating frequency
#define UART1_BAUD 9600
#define UART2_BAUD 9600
#define UBRG1_VALUE (FCY/UART1_BAUD)/16 - 1
#define UBRG2_VALUE (FCY/UART2_BAUD)/16 - 1
//------------------------------------------ Config bits
// Configuration settings
_FOSC(CSW_FSCM_OFF && FRC_PLL16); // Fosc=16x7.5MHz, i.e. 30 MIPS
// 16 x 7.5=120 MHz
//120/4=30MHz
//1/30M*x=delay
_FWDT(WDT_OFF); // Watchdog timer off
_FBORPOR(MCLR_EN); // Disable reset pin
int main(void)
unsigned char MSG[]= "o";
OpenUART1();
while (1)
PrintStringUART1(MSG);
WriteCharToUART1(11);
// WriteCharToUART1(13);
return 0;
void OpenUART1(void)
TRISFbits.TRISF2 = 1;
TRISFbits.TRISF3 = 0;
U1MODEbits.ALTIO = 0;
U1MODEbits.PDSEL = 0; // 8 bits no parity
U1MODEbits.STSEL = 0; //1 stop bit
U1BRG = 194; //calculated according to baud rate 9600
U1MODEbits.UARTEN = 1; //enable tx rx pins
U1STAbits.UTXEN = 1; // enable transmit
char BusyUART1 (void)
if(!IFS0bits.U1TXIF)
return 1;
else
IFS0bits.U1TXIF =0;
return 0;
void PrintStringUART1 (unsigned char *String)
while (*String)
WriteCharToUART1 (*String++);
void WriteCharToUART1 (unsigned char Data)
U1TXREG = Data;
while (BusyUART1()); __delay32(15000000);
13,756
13,756
Hi Pat, welcome to EP.
Please use the 'Insert... Code' button next time to make your post better readable.
Harald
DJPat
Nov 4, 2016
Nov 4, 2016
Alright, thank you. I didn't know there was an option for that.. I see it now:)
NorthGuy
Mar 24, 2016
53
Mar 24, 2016
53
The oscillator is 7.37, not 7.5 MHz. So the baud should be 191 instead of 194. Not a big difference, but who knows, combined with the oscillator error of 2%, might be enough to screw up.
Amar Dhore
Dec 2, 2015
129
Dec 2, 2015
129
In a while loop
Code:
while (1)
PrintStringUART1(MSG); //you are increasing index in a while loop. This function is a bit fishy
and your array unsigned char MSG[]= "o"; is of a size 1 and
in the function PrintStringUART1() you are increasing you array index which I think spitting out the garbage because its not initialize.
try this:
char MSG[]= "Hello World";
when you send a message, count the byte
while(length of a string)
U1TXREG = MSG[i++];
wait for PIC to send a char
