Serial Communication with dsPIC30F4011
Discussion in 'Microcontrollers, Programming and IoT' started by DJPat, Nov 4, 2016.
  1. DJPat
    DJPat
    Nov 4, 2016
    Hi..I've been trying to get my serial communication on the dsPIC to work. I need to be able to transmit and receive at least one character but all I seem to get is an junk transmission. I'm not sure if my code is right. I've tried a max232 circuit and an off the shelf usb-to-serial bridge. Both give the same output. I've also made sure the baud rates are correct. Please help.
    Here's my code:
    //------------------------------------------- Defines
    #include <p30f4011.h>
    #include <xc.h>
    #include <libpic30.h>
    #include <ports.h>
    #include <dsp.h>
    #include <math.h>
    #define FCY (unsigned long) 30000000 //add your operating frequency
    #define UART1_BAUD 9600
    #define UART2_BAUD 9600
    #define UBRG1_VALUE (FCY/UART1_BAUD)/16 - 1
    #define UBRG2_VALUE (FCY/UART2_BAUD)/16 - 1
    //------------------------------------------ Config bits
    // Configuration settings
    _FOSC(CSW_FSCM_OFF && FRC_PLL16); // Fosc=16x7.5MHz, i.e. 30 MIPS
    // 16 x 7.5=120 MHz
    //120/4=30MHz
    //1/30M*x=delay
    _FWDT(WDT_OFF); // Watchdog timer off
    _FBORPOR(MCLR_EN); // Disable reset pin
    int main(void)
    unsigned char MSG[]= "o";
    OpenUART1();
    while (1)
    PrintStringUART1(MSG);
    WriteCharToUART1(11);
    // WriteCharToUART1(13);
    return 0;
    void OpenUART1(void)
    TRISFbits.TRISF2 = 1;
    TRISFbits.TRISF3 = 0;
    U1MODEbits.ALTIO = 0;
    U1MODEbits.PDSEL = 0; // 8 bits no parity
    U1MODEbits.STSEL = 0; //1 stop bit
    U1BRG = 194; //calculated according to baud rate 9600
    U1MODEbits.UARTEN = 1; //enable tx rx pins
    U1STAbits.UTXEN = 1; // enable transmit
    char BusyUART1 (void)
    if(!IFS0bits.U1TXIF)
    return 1;
    else
    IFS0bits.U1TXIF =0;
    return 0;
    void PrintStringUART1 (unsigned char *String)
    while (*String)
    WriteCharToUART1 (*String++);
    void WriteCharToUART1 (unsigned char Data)
    U1TXREG = Data;
    while (BusyUART1()); __delay32(15000000);
  2. Harald Kapp
    11,151
    2,545
    Hi Pat, welcome to EP.
    Please use the 'Insert... Code' button next time to make your post better readable.
    Harald
  3. DJPat
    DJPat
    Nov 4, 2016
    Alright, thank you. I didn't know there was an option for that.. I see it now:)
  4. NorthGuy
    NorthGuy
    53
    16
    Mar 24, 2016
    The oscillator is 7.37, not 7.5 MHz. So the baud should be 191 instead of 194. Not a big difference, but who knows, combined with the oscillator error of 2%, might be enough to screw up.
  5. Amar Dhore
    Amar Dhore
    129
    12
    Dec 2, 2015
    In a while loop
    Code:
    while (1)
    PrintStringUART1(MSG); //you are increasing index in a while loop. This function is a bit fishy
    and your array unsigned char MSG[]= "o"; is of a size 1 and
    in the function PrintStringUART1() you are increasing you array index which I think spitting out the garbage because its not initialize.
    try this:
    char MSG[]= "Hello World";
    when you send a message, count the byte
    while(length of a string)
    U1TXREG = MSG[i++];
    wait for PIC to send a char
