A
aman
I am designing an electronic interface to SCADA. The SCADA typically
takes 4-20 mA input for logging data to a central database. So I need
to convert my voltage output from my instrument/device into current
using a V/I convertor(like AD1B22).
My instrument has just one analog out but I need 4 lines to interface
to SCADA. For this I am using a 4:1 MUX. Now since these 4 lines should
hold valid data at all times I need to latch in voltage values before
converting them to current outputs. I was thinking of using sample and
hold circuit to latch analog voltage values. When I looked at sample
and hold circuit like AD585, the data sheet talks about droop
rate(change in output voltage with time due to leakage capacitive
current).
So I am thinking that the only way to latch analog voltage is to
convert it into digital, then latch the voltage and convert it back to
analog. Am I thinking on correct lines or not ? Any other ideas ?
current).
