T
t
I have a 100 hp 480 volt motor with a reduced voltage auto transformer
starter, Square D.
We have the taps set at 65% to achieve the torque required to start the
motor.
I need to set the time delay between the start of the reduced voltage to the
switch to full voltage.
We have set it to about 5 seconds. We listened to the motor while starting
and have it switch over before the speed at the reduced voltage levels out.
It seems ok but I want it to be set perfectly.
I am going to use a RPM meter and I need to know at what speed should the
starter switch over to full voltage?
Some of the literature that came with the starters say to set to switch over
at 80% to 85% full speed. Or to do it by ear as we have already done.
Now if the nameplate RPM is 1750 rpm and 85% of that is 1400 rpm, then the
switch over would be at 1400 rpm?
Or should it switch over at 85% of reduced voltage full speed?
The nameplate RPM 1750 at 65% transformer tap is 1138 rpm this is the
reduced voltage full speed.
At 85% of the reduced voltage the speed would be 967 rpm.
Or do I have it wrong and 1400 rpm is the switch over speed.
Will the motor get to nameplate RPM at the reduced voltage?
I'm so confused
t
starter, Square D.
motor.
I'm so confused
t
