How car jump starters work?
P
Phil Allison
Joel Kolstad
siliconmike said:
I would like to know how those commercially available jump starters
provide hundreds of cranking amperes to start cars?
They have a battery inside of them! A brick-sized battery can easily provide
100 amps for a little while (typically it'd be something like a 12V, 2Ah
battery, which will provide 100A for about 1 minute... and that's only if the
car's battery is completely dead).
Simply, what is the electronics behind this?
I've never taken one apart, but I believe it's just some simple charging
circuit and probably a good-sized Schottky diode to prevent incorrect hookup.
P
Phil Allison
"Joel Kolstad"
provide 100 amps for a little while (typically it'd be something like a
12V, 2Ah battery, which will provide 100A for about 1 minute... and that's
only if the car's battery is completely dead).
** From the size and weight ( 21 pounds) of the unit, SLA battery of about
18 AH is more likely.
http://www.batterywholesale.com/battery-store/proddetail.html?prodID=377
At circa $31 it comes well within the cost too.
........ Phil
S
Stanislaw Flatto
Here is an example jump starter:
http://automotive.hardwarestore.com/11-16-battery-jumper-cables/vector-jump-start-system-100762.aspx
Any explanation / hint would be very much appreciated.
Mike
Hint - a well charged battery, for the few seconds till the motor starts
(or NOT). Won't work if your original battery developed a short!
Stanislaw
Slack user from Ulladulla.
The battery is connected directly to the outside world on the alligator
clips; you connect it up wrong, you fry...
The complexity of the charge circuit depends on the product model. Some
of them have a simple LED state-of-charge indicator and these models
tend to have slightly more complex charge circuits. These products are
designed to be plugged into AC longterm, and as such they are float
charge circuits - typically an adjustable regulator (TO-220 package,
like an LM317) and a current-limiting resistor.
John - KD5YI
A diode can't prevent incorrect hookup.
