Hi, all,
First time poster and inexperienced electronics person here...
I have a little project: I am going to take some regular computer serial cables (DB9 connectors) and chop off one end. Then I'm going to solder a special connector I need on there instead. I have the pinouts, and (*knock on wood*) I think I can handle that.
The problem is, the special connector only uses 3 of the 9 wires (RX/TX/GRD). I am not trying to create a fire hazard or a communications issue, so what should I do with the other wires? Do I need to disconnect them from the head I'm not removing? Or is it adequate to make sure there is a good amount of the sheaf coming down past the end of the metal wire?
I appreciate your help in advance.
