Mini hi-fi Sony FH-B411 cd player won't play music, but tray works perfectly
Discussion in 'Troubleshooting and Repair' started by paula, Aug 14, 2014.
  1. paula
    paula
    Aug 14, 2014
    I think the answer might be " Throw it out. Buy a new one. ", but I'll askanyway.
    I have a Sony " Mini HiFi Component System " model FH-B411. The cd player won't play music.
    The cd tray opens and closes with no problem, but when you put on a music cd and then you close the tray it doesn't sound as if it spins the cd and therefore doesn't read it. Of course I tried with different cds but same result. The rest of the mini component system works perfectly.
    I haven't opened it because I want to know what should I'd be looking for, what is the "broken" part to fix. Also, I don't want to make it worse. Using the video option with an auxiliary cable cord I hook up my ipod or my portable cd player (I know very old) and has great sound. This one has wooden speaker boxes and sounds a lot better than any new ones I've listened to.
    I really would like to finally fix the cd player of the mini component system.
    I don't know if maybe I just open it and vacuum the dust it can be fixed, any ideas??
    Does anyone out there know what could be done???
    Thanks for any help,
    Paula
  2. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    You can carefully clean the CD lens with isopropyl alcohol.
  3. KrisBlueNZ
    8,393
    1,268
    Nov 28, 2011
  4. Gryd3
    Gryd3
    4,098
    875
    Jun 25, 2014
    Take care of the easy things first like the above posts suggest. If the CD does not spin at all there may be another issue.
    Is there a display on the device that flashes when it attempts to read a CD?
  5. shrtrnd
    shrtrnd
    3,714
    469
    Jan 15, 2010
    Yeah, either way, you're going to have to open the unit.
    It might be as simple as a switch that closes when the CD tray closes, and tells the player to start 'spinning' to read the disc.
    If you open the case and observe what happens when you insert a CD, it might point you in the right direction to find the problem.
  6. kpatz
    kpatz
    247
    52
    Feb 24, 2014
    Check the ribbon cables going to/from the CD transport to the main boards, and also the ribbon cable connecting the optical assembly. These can get oxidation on them, leading to flaky connections. I've seen this on some Sony consumer gear and cleaning/reseating them usually fixes the problem. :)
