The Jackal
- Feb 26, 2014
- 6
- Joined
- Feb 26, 2014
- Messages
- 6
I have been working on the idea I have. I have no electronic back round, however I will try my best to explain.
Can a transmitter/Receiver act as a switch????
I have 3 existing power sources of 12V each and a 3 relays of 12V each to switch on each individual light. I am looking for a wireless transmitter/receiver to switch on an additional LED light strip for each of the individual lines. (See attached illustration). Every Transmitter/Receiver must have its own frequency to prevent switching on/off each other.
LED modules specifications:
* Layout as in the picture
* Same type LEDs or ones using less power.
* Battery must be small (9v square battery size preferably). CR123 batteries will be optimum.
Transmitter/Receiver module specifications:
* Must be max 30mm x 30mm max if possible.
* Slim as possible/ Compact
* Transmitter to work of an existing 12V power line.
* Must have a limited transmission distance of 1.5 meters.
* Should the module be used close to another person,the modules must not have an effect on other close by modules.
Questions:
* Can the transmitter act as a switch to switch on the LED strip at the receiver
* Can the transmitter work off the current 12V/12V relay power?
* Can the receiver work of a power supply that feed both the LED strip and Receiver at the same time?
Questions:
