Assalam o alaikum,
I am Asad Jabbar and recently joined this forum. I am in the 2nd semester of engineering and want some serious help.
Actually i am using a relay driver circuit to drive a dc motor at 7.4v and 2 ampere. The problem is that when i connect the output of receiver i.e., signal wire and ground wire on the circuit and try to run the motor it doesn't work but as instead when i am not using the receiver output and giving direct power with a 5v battery the relay driver circuit is working fine.
Now i want you guys to help me solve the issue to use my receiver output to drive the relay circuit when i use the signals from it.
Note: I am using 2.4ghz esky transmitter receiver. The voltage of signal-ground at static is 0.22v. When i forward the throttle stick it gives 0.28v and at reversing the throttle it gives 0.18v. one more thing the futaba servo is working fine with it.
Relay Driver Circuit
Regards
Regards
