P
Proctologically Violated©®
Awl--
I'm looking for P&B style double and triple pole, double throw relays, that
fit into a base. I don't know the number, or the generic style to search
on. Maybe you all have an idea.
One style has an 11 pin base (2 for the coil, 9 for the contacts), in a
rectanglur array. The pins are actually blade-like.
The relay itself is about 1x1" cross section, about 2-3" high, clear or
colored plastic, sometimes w/ an indicator light inside. It plugs into a
molded plastic base, which has screw terminals.
The other style has an octal/tube style base, that I'm less familiar with..
I used to find these surplus locally (NYC area), but no longer. Most of what
I found was not P&B, but clones.
Any ideas?
Also, are there cheap solid state equivalents that would work just as
well/cheaply?
Appreciate all help.
Any ideas?
well/cheaply?
