R
Roy and Rosa
PTK169AV had shorted hv splitter.
I dont have repair manual. I checked other posts I could find on net.
I replaced the 4 caps around smps. B+ in standby is 168 volts and drops to
160 volts in run.
I adjusted the pot labeled B+ reg, the one under the black snap cover, It
made no effect on standby and only drops to 159 volt in run.
I used RCA caps for 15 and 39 uf caps...105 deg.C for the other 2.
What else should I look for? Is there a pot I missed for standby
adjustment?
160 volts in run.
adjustment?
