PTK169 dead
Discussion in 'Electronic Repair' started by Mike, Jul 21, 2005.
  1. Mike
    Mike Guest
    Got this set, symptoms: dead, no startup, no power LED, no response from
    panel or IR.
    Removed the HV lead from the splitter, checked the hot, it is good. power
    supply starts, system will not.
    There is 137.8VDC standby B+ on the HOT.
    Any ideas?
  2. Guest
    What are the rest of the standby voltages?
  3. Rono
    Rono Guest
    There are many things that could cause it! Just "Google"
    the model, or chassis #, as dead! Check/replace CR4118!
    Common, Rono.
