RCA PTK169 chassis repair help
Discussion in 'Electronic Repair' started by [email protected], Nov 9, 2013.
  1. Guest
    I have a CTC169PGA chassis that died suddenly. I replaced the chopper transistor (Q4101) and regulator IC (U4101). When in standby, I am getting 14-15 volts on CR4118 but nothing on CR4116 (B+). Does this mean the supply isworking and there is a short on this line (HV splitter maybe or CR4116 bad)? Or could this still be a power supply issue?
    Jack
  2. Guest
    Sounds like 4116 is open. The old 243646. I use the same diode for 4118 actually.
    That power supply operates in like a "burst" mode when turned off. It will not go into "run" mode without horizontal drive.
    The rectifiers can check good on an ohmmeter and be bad.
