Problem with Treadmill
Mercury
Mar 31, 2020
Mar 31, 2020
Hi all
First post so be kind have a Dynamix IRMT904 treadmill not used it for a while but because I'm in lockdown for the next 12 weeks thought I'd get back on it.switched it on everything lit up as it should pressed start got the 3 second countdown but the belt didn't move had a look inside when you press start the motor moves for a fraction of a second then nothing checked motor with motorcycle battery it turns ok.Im an absolute newby but willing to learn have got a multi meter so I would like to fault find PCB but if it needs any components replacing will have to send it away for repair so any recommendations for a reliable repair company in the UK would be appreciated.Have read through some threads on the forum and seems like there's some great and knowledgeable people on here so hope someone can help me cheers
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
Is there any model No on the board?
Unfortunately there is only a couple of reverse engineered schematics for a some of the better known models.
