i Design a Unipolar stepper motor drive with tip122.
the motor run without any problem with 5v but when i try to run it with 12v it stop at the step and don't move and the tip122 became hot !.
note that the motor at 5v it use 3.5A from power supply and at 12v it use 7.5A from power supply.
is this problem because the high ampere ( so i need a current limiter ) or it because tip 122.
the circuit here
http://dl.dropbox.com/u/2193931/test1.JPG
the circuit here
