Problem in a circuit?
muashr
Feb 11, 2014
5
Feb 11, 2014
5
I have a question regarding the sub section of a power supply.
Background: I have two similar power supplies one is functioning whereas the other one is not functioning. The functioning one can output variable dc voltage from +(0 - 20)V. The nonfunctioning power supply can only deliver -4V at the output.
The sub circuit about which I have a question is at the output. Both supplies have similar sub circuit. This sub circuit consists of a transistor the base/gate of that transistor is connected in series with a red LED, this red LED is connected to a 1.5k SMD resistor and other end of this 1.5k is connected to a source point of +27V.
Both LEDs were tested in their corresponding sub circuits when the power was off and they appeared to be ok (Vf = +1.7V). Now the problem is that when the power is on the base/gate of the malfunctioning transistor gets only +0.1V whereas the base/gate of the functioning transistor gets +25V. Also the red LED of the malfunctioning power supply is on whereas that of the functioning remains off.
The voltage measured (with respect to ground) on the path/trace which joins LED and 1.5k SMD resistor is as follows.
Functioning Supply: +27v
Malfunctioning Supply: +2.2V
On measuring the voltage drop across these red LEDs following results are obtained.
Functioning Supply: -4V (red lead @ anode & black @ cathode) & +2.3V (black lead @ anode & red lead @ cathode)
Malfunctioning Supply: +2.1V (red lead @ anode & black @ cathode) & -2.1V (black lead @ anode & red lead @ cathode)
My question is whether or not LEDs are also used as some kind of fuses? If not, then what is your opinion about this situation?
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Nov 28, 2011
8,393
A picture paints a thousand words. How about uploading some schematics.
Rleo6965
Jan 22, 2012
585
Jan 22, 2012
585
Your lucky. You still have 1 functioning unit for resistance test comparison.
shrtrnd
Jan 15, 2010
3,876
Jan 15, 2010
3,876
What KrisBlueNZ said.
It sounds to me like you're dealing with a 'crowbar' circuit. It's designed to limit (effectively reduce the output voltage) if an overload condition exists.
The crowbar circuit itself can fail, resulting in a continuous limit of the power supply output that otherwise can't be explained.
Without looking at the circut, and only hearing the symptoms; that'd be my first guess.
But it's only a guess at this point.
Good luck troubleshooting the problem.
